Notes: Force can be used as a defensive strategy/buys time to regain possession of switch or scale depending on level.
Is boost a viable powerup? Can someone explain to me a situation in which boost level 1 or 2 would be an effective use of time?
You can use boost 1 or 2 if you don’t think you will get a third cube in time to use boost 3. You can also use boost 1 if you don’t think you will ever recover the scale.
Please note that boost is based on ADDITIONAL points earned, not net points. I would have edited this in, but I can’t edit the post at the moment. Apparently, the site thinks I may be a bot because I’m so new. That’s fair enough I suppose.
