Pressure Gauge
I cant seem to find the pressure gauge that hooks up to the pressure switch and the relief valve
the kit only gives two pressure gauges right? If I attached both of them to my main and secondary regulators, does that mean I have to purchase another pressure gauge?
also, what is a sub base? what is a gasket? did the kit provide gaskets?
Thank you!
Look at Page 13 of the pneumatics manual. The only gauges you really are required to have are the two closest to the compressor: One to show the compressor output pressure (located by the relief valve) and one to show the regulated “working” pressure (at the Norgren regulator). The third gauge shown at the Monnier regulator is optional, only of you need both 60 PSI and some other, lower pressure.
Don
