Pressure Switch Read out
Hey guys i was wondering if there is anyway that I can get a read out of the air pressure on my dashboard. Please reply
Out-of-the-box the cRIO just knows if the compressor is running or not.
The pressure switch that comes in the kit just senses a drop below 95psi and a rise above 115psi.
For actual pressure you’d need to purchase a pressure transducer sensor that the cRIO could read and return the value to the Dashboard.
The pressure SWITCH is just that - a switch. On or Off, nothing in between.
If you could find a pressure SENSOR you could easily read the pressure.
