Prgm4 2 joystics control 1 speed cntrl???
Can someone tell me how to program 2 of the joystick ports to operate 1 pwm output???
Why would you want to have two joysticks control the same PWM output? Seems redundantly redundant to me.
Do you mean two pwm’s on one joystick, because i don’t think it’s even possible to control one pwm with two joysticks. I mean, you could, but it would be rather pointless.
To control two pwm’s with one joystick is easy:
serout [255,255,pwm1,relay1,pwm2,relay2,pwm3,pwm4…pwm16]
just replace which ever pwm with the variable of the joystick…
serout [255,255,p1_y,relay1,p1_y, relay2,pwm3,pwm4…pwm16]
if this makes no sense, sorry, but i’m typing this on like, no sleep, and well, it makes sense to me. :smiley:
Thanks for replying. What I want is for forward on two joystics to work the same PWM output. Call me crazy but there’s a long story of why I need it.
this is just off the top of my head… but i think it may go something like this…
If p1_y > p2_y then use1
pwm1 = p2_y
goto end
use1
pwm1=p1_y
end:
basically it takes whichever joystick is greater and uses that as the output to pwm1
you would have to edit the serout command so that it would read
[255,255,pwm1,relayA,p2_y,relayB,p3_y,p4_y,p1_x,p2_x,p3_x,p4_x,p1_wheel,p2_wheel,p3_wheel,p4_wheel,127,127,127,127]
just remember if you did this you couldnt use pwm2 because p2_y would still control it as well as pwm1 if you went forward.
*Originally posted by Joseph F *
The problem with that solution is that you won’t be able to go in reverse (since joystick centered is 127 and joystick reverse is less than 127).
then edit it to read:
If p1_y | p2_y < 115 then rev
if p1_y | p2_y > 135 then fwd
pwm1 = 127
goto end
fwd:
pwm1 = p2_y
goto end
use1
pwm1=p1_y
goto end
rev:
if p1_y < p2_y then use2
pwm1 = p2_y
goto end
use2:
pwm1 = p1_y
end:
Try this
pwm1 = (p1_y + p2_y) / 2
