Hi,
I am trying to print the examples in the printf_lib.c commented examples.
I initialized the variables as directed and then called the following each second.
Transmitting before initializing the UART results in the notorious red-green light problem. As for bad initialization, I can’t tell you.
IFI’s implementation of printf doesn’t do all the control codes that the PC versions use. But the code given is copied from printf_lib.c (lines 19 through 27)
It looks like it’s loosing characters, either totally or just garbled. They come through interminently, but when they come in they are intact. (a baud-rate mismatch usually results in framing errors, garbage, and/or extra/lost bytes)
Explicitly cast the integer arguments being provided to printf
to the desired type. If x is an int, y is a int, and z is a long,
use: printf("%d %d %lx
", (int)x, (int)y, (long)z);
The default way in which arguments are pushed, for routines
that do not have their arguments declared, is char. This is a
property of the MicroChip C-Bot compiler enironment. You may
influence this behavior by changing settings, but who knows what
else will break if you do that. The only place the problem seems
to appear is the printf calls, because the arguments for all the
other routines are explicitly declared. It is not hard to provide
the required type casts to the printf calls.
The fact that you can’t print a long using the provided printf()
is quite a bother. If you would like a routine that addresses that
problem, refer to the file pl.c available in the EiC.zip file available
in the technical page at www.srvhsrobotics.org The code involved
is described in the programming tutorial (well, perhaps not quite
a tutorial) available from the same web page.
