I’m not entirely sure why PTC decided to do this, but I use Creo Parametric 2.0 in a professional capacity and have access to a licensed copy of the system through my work. Unfortunately it seems that the models provided by PTC are limited to educational versions. The specific error is “The file “XXX” was created using an educational version of Creo Parametric and is not compatible with the version of Creo Parametric you are running.”
Is there a way to access these files without using the non-PTC versions?
