Problem installing AprilTags library for Python (Windows 10)
Hey! So I’m trying to install an AprilTags library to work with AprilTag detection in Python, the package in question can be found at apriltag · PyPI
The library itself is a C extension. The publisher of the package did not include any wheels, and left up only the source dist. Therefore, installing requires the C toolchain to be installed which (at least for me), has been a pretty cumbersome process on Windows.
After searching for answers beforehand, I did come a cross this post, although at least to my understanding, there wasn’t any solution that came up on Windows.
I have Visual Studio Build Tools 2019 installed, and the problem described in the error seems to be something related to CMake (I have version 3.28.2)
Error here ```python3 Collecting apriltag Using cached apriltag-0.0.16.tar.gz (201 kB) Preparing metadata (setup.py) ... done Building wheels for collected packages: apriltag Building wheel for apriltag (setup.py) ... error error: subprocess-exited-with-error
× python setup.py bdist_wheel did not run successfully.
│ exit code: 1
╰─> [105 lines of output]
running bdist_wheel
running build
running build_py
creating build
creating build\lib.win-amd64-cpython-310
copying python\apriltag.py → build\lib.win-amd64-cpython-310
running build_ext
C:\Users\GDKID\AppData\Local\Temp\pip-install-k4g9iceh\apriltag_fcdb4ef49a0a48cb9c409acf6ba86f96\setup.py:30: DeprecationWarning: distutils Version classes are deprecated. Use packaging.version instead.
cmake_version = LooseVersion(re.search(r’version\s*([\d.]+)', out.decode()).group(1))
– Building for: Visual Studio 16 2019
CMake Warning (dev) at CMakeLists.txt:1 (project):
cmake_minimum_required() should be called prior to this top-level project()
call. Please see the cmake-commands(7) manual for usage documentation of
both commands.
This warning is for project developers. Use -Wno-dev to suppress it.
  -- Selecting Windows SDK version 10.0.19041.0 to target Windows 10.0.19045.
  -- The C compiler identification is MSVC 19.29.30153.0
  -- The CXX compiler identification is MSVC 19.29.30153.0
  -- Detecting C compiler ABI info
  -- Detecting C compiler ABI info - done
  -- Check for working C compiler: C:/Program Files (x86)/Microsoft Visual Studio/2019/BuildTools/VC/Tools/MSVC/14.29.30133/bin/Hostx64/x64/cl.exe - skipped
  -- Detecting C compile features
  -- Detecting C compile features - done
  -- Detecting CXX compiler ABI info
  -- Detecting CXX compiler ABI info - done
  -- Check for working CXX compiler: C:/Program Files (x86)/Microsoft Visual Studio/2019/BuildTools/VC/Tools/MSVC/14.29.30133/bin/Hostx64/x64/cl.exe - skipped
  -- Detecting CXX compile features
  -- Detecting CXX compile features - done
  CMake Deprecation Warning at CMakeLists.txt:3 (cmake_minimum_required):
    Compatibility with CMake < 3.5 will be removed from a future version of
    CMake.
    Update the VERSION argument <min> value or use a ...<max> suffix to tell
    CMake that the project does not need compatibility with older versions.
  -- Performing Test CMAKE_HAVE_LIBC_PTHREAD
  -- Performing Test CMAKE_HAVE_LIBC_PTHREAD - Failed
  -- Looking for pthread_create in pthreads
  -- Looking for pthread_create in pthreads - not found
  -- Looking for pthread_create in pthread - not found
  -- Found Threads: TRUE
  -- Found PkgConfig: D:/pkg-config/bin/pkg-config.exe (found version "0.26")
  -- Checking for one of the modules 'opencv>=2.3;opencv-2.3.1;opencv-3.0.0'
  -- Configuring done (14.0s)
  -- Generating done (0.1s)
  CMake Warning:
    Manually-specified variables were not used by the project:
      PYTHON_EXECUTABLE
  -- Build files have been written to: C:/Users/GDKID/AppData/Local/Temp/pip-install-k4g9iceh/apriltag_fcdb4ef49a0a48cb9c409acf6ba86f96/build/temp.win-amd64-cpython-310/Release
  Microsoft (R) Build Engine version 16.11.2+f32259642 for .NET Framework
  Copyright (C) Microsoft Corporation. All rights reserved.
  C:\Program Files (x86)\Microsoft Visual Studio\2019\BuildTools\MSBuild\Microsoft\VC\v160\Microsoft.CppBuild.targets(517,5): warning MSB8029: The Intermediate directory or Output directory cannot reside under the Temporary directory as it could lead to issues with incremental build. [C:\Users\GDKID\AppData\Local\Temp\pip-install-k4g9iceh\apriltag_fcdb4ef49a0a48cb9c409acf6ba86f96\build\temp.win-amd64-cpython-310\Release\ZERO_CHECK.vcxproj]
    1>Checking Build System
  C:\Program Files (x86)\Microsoft Visual Studio\2019\BuildTools\MSBuild\Microsoft\VC\v160\Microsoft.CppBuild.targets(517,5): warning MSB8029: The Intermediate directory or Output directory cannot reside under the Temporary directory as it could lead to issues with incremental build. [C:\Users\GDKID\AppData\Local\Temp\pip-install-k4g9iceh\apriltag_fcdb4ef49a0a48cb9c409acf6ba86f96\build\temp.win-amd64-cpython-310\Release\core\apriltag.vcxproj]
    Building Custom Rule C:/Users/GDKID/AppData/Local/Temp/pip-install-k4g9iceh/apriltag_fcdb4ef49a0a48cb9c409acf6ba86f96/core/CMakeLists.txt
  cl : command line error D8021: invalid numeric argument '/Wsign-compare' [C:\Users\GDKID\AppData\Local\Temp\pip-install-k4g9iceh\apriltag_fcdb4ef49a0a48cb9c409acf6ba86f96\build\temp.win-amd64-cpython-310\Release\core\apriltag.vcxproj]
  Traceback (most recent call last):
    File "<string>", line 2, in <module>
    File "<pip-setuptools-caller>", line 34, in <module>
    File "C:\Users\GDKID\AppData\Local\Temp\pip-install-k4g9iceh\apriltag_fcdb4ef49a0a48cb9c409acf6ba86f96\setup.py", line 62, in <module>
      setup(
    File "D:\random-shit\venv\lib\site-packages\setuptools\__init__.py", line 87, in setup
      return distutils.core.setup(**attrs)
    File "D:\random-shit\venv\lib\site-packages\setuptools\_distutils\core.py", line 177, in setup
      return run_commands(dist)
    File "D:\random-shit\venv\lib\site-packages\setuptools\_distutils\core.py", line 193, in run_commands
      dist.run_commands()
    File "D:\random-shit\venv\lib\site-packages\setuptools\_distutils\dist.py", line 968, in run_commands
      self.run_command(cmd)
    File "D:\random-shit\venv\lib\site-packages\setuptools\dist.py", line 1217, in run_command
      super().run_command(command)
    File "D:\random-shit\venv\lib\site-packages\setuptools\_distutils\dist.py", line 987, in run_command
      cmd_obj.run()
    File "D:\random-shit\venv\lib\site-packages\wheel\bdist_wheel.py", line 368, in run
      self.run_command("build")
    File "D:\random-shit\venv\lib\site-packages\setuptools\_distutils\cmd.py", line 317, in run_command
      self.distribution.run_command(command)
      cmd_obj.run()
    File "D:\random-shit\venv\lib\site-packages\setuptools\command\build.py", line 24, in run
      super().run()
    File "D:\random-shit\venv\lib\site-packages\setuptools\_distutils\command\build.py", line 131, in run
      self.run_command(cmd_name)
      cmd_obj.run()
    File "C:\Users\GDKID\AppData\Local\Temp\pip-install-k4g9iceh\apriltag_fcdb4ef49a0a48cb9c409acf6ba86f96\setup.py", line 35, in run
      self.build_extension(ext)
    File "C:\Users\GDKID\AppData\Local\Temp\pip-install-k4g9iceh\apriltag_fcdb4ef49a0a48cb9c409acf6ba86f96\setup.py", line 60, in build_extension
      subprocess.check_call(['cmake', '--build', '.'] + build_args, cwd=self.build_temp)
    File "D:\Python\lib\subprocess.py", line 369, in check_call
      raise CalledProcessError(retcode, cmd)
  subprocess.CalledProcessError: Command '['cmake', '--build', '.', '--config', 'Release', '--', '/m']' returned non-zero exit status 1.
  [end of output]
note: This error originates from a subprocess, and is likely not a problem with pip.
ERROR: Failed building wheel for apriltag
Running setup.py clean for apriltag
Failed to build apriltag
ERROR: Could not build wheels for apriltag, which is required to install pyproject.toml-based projects
</details>
Any help is appreciated. Thanks!
I wouldn’t bother. Just use robotpy-apriltag instead, we distribute wheels for all major platforms.
Oh sweet, I’ll look into that.
t
