Its me again, this time needing help with the cRio. I can connect the cRio to the computer and deploy code to the cRio, but when i log into the driver station user, the led for robot code is red.
The cRio is correctly imaged for labview and the deployment dialog box automatically closes when the deployment is complete, just like it should. I need a little help.
did you input your team number into the box on the setup tab? It needs to have the IP of 10.40.58.5 for it to work for you.
Also, make sure you are clicking the run button from Robot Main.vi, or nothing will work at all.
The ip address was actually the first thing i checked, and i also deployed the code from the robot main.vi. I wasnāt sure if this was a rookie programmerās mistake or not lol. I donāt know much about programming, but i am learning as i go, but these little things frustrate me a little but oh well, happens.
Hmm⦠those are the only things I can think of to troubleshoot it. Have you tried building and running the code as startup? I know it does take longer, but if it works, then that would confuse me even more.
What do you mean by ābuilding and running the code as startupā? As I said, i am a rookie programmer still learning and getting used to all of the programming jargon. Lol:D
In the project explorer, down at the bottom, there is a yellow icon next to what I believe to remember to be FRC Startup Program (or something of the like, its the one all the way down on the list). Click the plus symbol to the left of that, and a new thing will drop down. Right click on this new icon and click on āBuildā. Once that has happened, right click that icon again, and select āRun as Startupā. This will load your code onto the robot and it will remain there until you overwrite it using the same method. Using the run button will only keep the code in the controllers memory until it is rebooted, where it will be deleted. This will make it permanent.
Oh okay, I will try that when i get there today. Thanks for the help. I thought that when the code was run, it would stay on the cRio, but i guess i was wrong :rolleyes:
It took us over 2 weeks when it was first released to finally find that one line in that obscure manual on some other site to realize thatās what you have to do to keep it on there⦠So donāt feel bad about it.
Thanks, Cecil, that worked. So everytime i need to deploy code i need to build and then run as startup? That makes sense. Thanks once again
You can attempt to run the program from Robot Main.vi, as you were trying to do. Doing this, you can open up your code and do what is called a āprobeā to see what values are being input or output from any wire. As I said though, this code will not remain on the controller after a reboot. The only way to permanently keep the code on the controller is using the Build and Run as Startup method. Good luck this year!
Thanks for all the help.
