Problem with configureButtonBinding
Hi guys,
I’m trying to figure out how to bind our XBox controller buttons to some commands.
I’ve read the document here, but we’re still struggling to make a command work.
Our code is available here.
What am I doing wrong?
Thanks for helping
I see you just committed a change to Robot.teleopPeriodic() that I was about to suggest, removing the interfering a button code. Did that fix it?
Also, you should remove the scheduler run from teleopPeriodic. Your call to run in robotPeriodic should be sufficient.
