Hey, we are experiencing some issues with building our project after installing CTRE Phoenix and navX libraries. Can someone help us? The build scan can be found here.
This is our build.gradle
file:
plugins {
id "java"
id "edu.wpi.first.GradleRIO" version "2019.2.1"
sourceCompatibility = JavaVersion.VERSION_11
targetCompatibility = JavaVersion.VERSION_11
def ROBOT_MAIN_CLASS = "frc.robot.Main"
// Define my targets (RoboRIO) and artifacts (deployable files)
// This is added by GradleRIO's backing project EmbeddedTools.
deploy {
targets {
roboRIO("roborio") {
// Team number is loaded either from the .wpilib/wpilib_preferences.json
// or from command line. If not found an exception will be thrown.
// You can use getTeamOrDefault(team) instead of getTeamNumber if you
// want to store a team number in this file.
team = frc.getTeamOrDefault(5987)
artifacts {
frcJavaArtifact('frcJava') {
targets << "roborio"
// Debug can be overridden by command line, for use with VSCode
debug = frc.getDebugOrDefault(false)
// Built in artifact to deploy arbitrary files to the roboRIO.
fileTreeArtifact('frcStaticFileDeploy') {
// The directory below is the local directory to deploy
files = fileTree(dir: 'src/main/deploy')
// Deploy to RoboRIO target, into /home/lvuser/deploy
directory = '/home/lvuser/deploy'
// Set this to true to enable desktop support.
def includeDesktopSupport = false
// Maven central needed for JUnit
repositories {
mavenCentral()
// Defining my dependencies. In this case, WPILib (+ friends), and vendor libraries.
// Also defines JUnit 4.
dependencies {
compile wpi.deps.wpilib()
compile wpi.deps.vendor.java()
compile navx()
compile ctre()
nativeZip wpi.deps.vendor.jni(wpi.platforms.roborio)
nativeDesktopZip wpi.deps.vendor.jni(wpi.platforms.desktop)
testCompile 'junit:junit:4.12'
// Setting up my Jar File. In this case, adding all libraries into the main jar ('fat jar')
// in order to make them all available at runtime. Also adding the manifest so WPILib
// knows where to look for our Robot Class.
jar {
from { configurations.compile.collect { it.isDirectory() ? it : zipTree(it) } }
manifest edu.wpi.first.gradlerio.GradleRIOPlugin.javaManifest(ROBOT_MAIN_CLASS)
Thank you!
