our FRC II crio is wedged
we tried running a code, and we could not connect the crio to our driver station.
the crio is stuck in safe mode and we can not find it with the imaging tool
what can we do?
what can we do?
Have you verified your ip settings? I would try using the imaging tool with the an automatic ip address and your wireless adapter off. It sounds like it might be a connection issue
Make sure to download the new Utilities update here (http://joule.ni.com/nidu/cds/view/p/id/2262). This helps with connection issues to the cRIO-II.
Over the weekend, I experienced problems like this (which are specifically targed by the new Utilities update) when connecting to our cRIO-II. They were cleared up by shutting down all of my network adapters other than the one I was using. Then, I used the Utilities update today as well. After a couple of flashes, it worked properly.
