// Copyright (c) FIRST and other WPILib contributors.
// Open Source Software; you can modify and/or share it under the terms of
// the WPILib BSD license file in the root directory of this project.
#include “Robot.h”
#include <frc/smartdashboard/SmartDashboard.h>
#include <spdlog/spdlog.h>
namespace utils
double Deadband(double value, double deadband = 0.1)
if (std::abs(value) < deadband)
return 0;
if (value >= 0)
return (value - deadband) / (1.0 - deadband);
else
return (value + deadband) / (1.0 - deadband);
} // namespace utils
void Robot::RobotInit()
m_leftMotor.SetIdleMode(rev::CANSparkMax::IdleMode::kBrake);
m_leftMotorFollower.SetIdleMode(rev::CANSparkMax::IdleMode::kBrake);
m_rightMotor.SetIdleMode(rev::CANSparkMax::IdleMode::kBrake);
m_rightMotorFollower.SetIdleMode(rev::CANSparkMax::IdleMode::kBrake);
// #if IS_CLIMBER_PID
// m_setpoint = 0.0;
// m_encoderClimber.Reset();
// m_integrative = 0.0;
// m_lastError = 0.0;
// frc::SmartDashboard::PutNumber(“setpoint”, 0.0);
// frc::SmartDashboard::PutNumber(“speedCoef”, 0.0);
// #endif
m_leftMotor.RestoreFactoryDefaults();
m_leftMotorFollower.RestoreFactoryDefaults();
m_rightMotor.RestoreFactoryDefaults();
m_rightMotorFollower.RestoreFactoryDefaults();
m_leftMotorFollower.Follow(m_leftMotor);
m_rightMotorFollower.Follow(m_rightMotor);
m_leftMotor.SetInverted(true);
m_leftMotorFollower.SetInverted(true);
m_rightMotor.SetInverted(false);
m_rightMotorFollower.SetInverted(false);
void Robot::RobotPeriodic()
void Robot::TeleopInit()
m_solenoidClimber.Set(frc::DoubleSolenoid::Value::kForward);
m_solenoidRotatingArms.Set(frc::DoubleSolenoid::Value::kForward);
- This function is called periodically during operator control.
void Robot::TeleopPeriodic()
double offset = m_joystickLeft.GetThrottle() + m_joystickRight.GetThrottle() * 0.1;
frc::SmartDashboard::PutNumber(“Offset”, offset);
bool isAnyPTOEnabled = m_solenoidClimber.Get() == frc::DoubleSolenoid::Value::kReverse ||
m_solenoidRotatingArms.Get() == frc::DoubleSolenoid::Value::kReverse;
double speedCoefficientLeft = m_solenoidClimber.Get() == frc::DoubleSolenoid::Value::kReverse ? 0.4 : 0.2;
double speedCoefficientRight = m_solenoidRotatingArms.Get() == frc::DoubleSolenoid::Value::kReverse ? 0.8 : 0.2;
double speedRight = utils::Deadband(-m_joystickRight.GetY(), 0.15) * speedCoefficientRight;
double speedLeft = utils::Deadband(-m_joystickLeft.GetY(), 0.15) * speedCoefficientLeft;
frc::SmartDashboard::PutNumber(“speedRight”, speedRight);
frc::SmartDashboard::PutNumber(“speedLeft”, speedLeft);
if (m_joystickLeft.GetRawButtonPressed(1))
frc::DoubleSolenoid::Value value = m_solenoidClimber.Get() == frc::DoubleSolenoid::Value::kForward ? frc::DoubleSolenoid::Value::kReverse : frc::DoubleSolenoid::Value::kForward;
m_solenoidClimber.Set(value);
if (m_joystickRight.GetRawButtonPressed(1))
frc::DoubleSolenoid::Value value = m_solenoidRotatingArms.Get() == frc::DoubleSolenoid::Value::kForward ? frc::DoubleSolenoid::Value::kReverse : frc::DoubleSolenoid::Value::kForward;
m_solenoidRotatingArms.Set(value);
if (m_joystickRight.GetRawButtonPressed(2))
if (m_compressor.Enabled())
m_compressor.Disable();
else
m_compressor.EnableDigital();
if (m_solenoidClimber.Get() == frc::DoubleSolenoid::Value::kReverse)
m_leftMotor.Set(speedLeft + offset);
if (m_solenoidRotatingArms.Get() == frc::DoubleSolenoid::Value::kReverse)
m_rightMotor.Set(-speedRight);
if (!isAnyPTOEnabled)
m_leftMotor.Set(speedLeft);
m_rightMotor.Set(speedRight);
if (m_joystickLeft.GetRawButton(6))
// frc::SmartDashboard::PutNumber(“encodeur climber”, m_encoderClimber.Get().value());
// frc::SmartDashboard::PutNumber(“error”, m_error);
// frc::SmartDashboard::PutNumber(“integrative”, m_integrative);
// frc::SmartDashboard::PutNumber(“derivative”, m_derivative);
// frc::SmartDashboard::PutNumber(“speedClimber_PID”, m_speedPID);
// m_speedCoef = frc::SmartDashboard::GetNumber(“speedCoef”, 0.0);
// m_setpoint = std::clamp(frc::SmartDashboard::GetNumber(“setpoint”, 0.0), 0.0, MAX_HEIGHT_CLIMBER);
// m_error = m_setpoint - m_encoderClimber.Get().value();
// m_integrative += (m_error * 0.02);
// m_derivative = (m_error - m_lastError) / .02;
// m_lastError = m_error;
// m_speedPID = std::abs(m_speedCoef) * std::clamp(kP * m_error + kI * m_integrative + kD * m_derivative, -1.0, 1.0);
// if (m_joystickLeft.GetRawButton(5))
// m_leftMotor.Set(m_speedPID);
// else
// m_leftMotor.Set(0.0);
// #endif
- This function is called periodically during test mode.
void Robot::TestPeriodic() {}
#ifndef RUNNING_FRC_TESTS
int main()
return frc::StartRobot();
#endif
