Hey CD,
Right now I’m working on a PID control using the TalonSRX built in closed loop controls and nothing is working.
I try to use the Speed control mode (TalonControlMode.Speed), I set everything just as they did in the examples that CTRE provided and either nothing is happening or it goes full speed even though I try and set it to 30 RPM.
Using the SRX Magnetic Encoder
Here is the code:
package org.usfirst.frc.team5951.robot;
import com.ctre.CANTalon;
import com.ctre.CANTalon.FeedbackDevice;
import com.ctre.CANTalon.TalonControlMode;
import edu.wpi.first.wpilibj.XboxController;
* The VM is configured to automatically run this class, and to call the
* functions corresponding to each mode, as described in the IterativeRobot
* documentation. If you change the name of this class or the package after
* creating this project, you must also update the manifest file in the resource
* directory.
private CANTalon flywheelMotor;
private XboxController controller;
* This function is run when the robot is first started up and should be
* used for any initialization code.
@Override
public void robotInit() {
this.flywheelMotor = new CANTalon(8);
this.flywheelMotor.changeControlMode(TalonControlMode.Speed);
this.flywheelMotor.setFeedbackDevice(FeedbackDevice.CtreMagEncoder_Relative);
this.flywheelMotor.reverseSensor(true);
this.flywheelMotor.setInverted(true);
this.flywheelMotor.configNominalOutputVoltage(0.0f, -0.0f);
this.flywheelMotor.configPeakOutputVoltage(+12.0f, -12.0f);
this.flywheelMotor.setPosition(0);
this.flywheelMotor.setProfile(0);
this.flywheelMotor.setF(0);
this.flywheelMotor.setP(0.2);
this.flywheelMotor.setI(0.00);
this.controller = new XboxController(0);
* This autonomous (along with the chooser code above) shows how to select
* between different autonomous modes using the dashboard. The sendable
* chooser code works with the Java SmartDashboard. If you prefer the
* LabVIEW Dashboard, remove all of the chooser code and uncomment the
* getString line to get the auto name from the text box below the Gyro
* You can add additional auto modes by adding additional comparisons to the
* switch structure below with additional strings. If using the
* SendableChooser make sure to add them to the chooser code above as well.
@Override
* This function is called periodically during autonomous
@Override
* This function is called periodically during operator control
@Override
if(this.controller.getAButton()) {
this.flywheelMotor.set(40);
} else if(this.controller.getYButton()) {
this.flywheelMotor.set(0);
SmartDashboard.putNumber("Speed: ", this.flywheelMotor.getPosition());
SmartDashboard.putNumber("Error: ", this.flywheelMotor.getError());
* This function is called periodically during test mode
@Override
public void testPeriodic() {
What am I missing?
