problems debugging
In Target Server Options,
do you always point the Kernel image to the
cRIOFRC_vxWorks image
regardless of the .out file you are trying to debug?
Ann
It depends on which version of the cRio that you have… If you have the 8 slot cRio… the answer is yes… if it is the newer 4 slot cRio, you use cRIOFRCII_vxWorks
-Wade
thanks for the response - I’m good now.
Ann
