Problems installing robotpy on roboRIO
Having trouble configuring our roboRIO to read python code using robotpy. I went through the downloading and installing process here:
https://robotpy.readthedocs.io/en/stable/install/robot.html
but nothing has worked. When I run the command: py -3 -m robotpy_installer install-robotpy
I get the return of this:
16:47:04:326 INFO    : robotpy.installer   : RobotPy Installer 2020.0.2
16:47:04:327 INFO    : robotpy.installer   : -> caching files at C:\Users\first\Desktop\2020 Robot
16:47:05:222 INFO    : robotpy.installer   : Finding robot for team 1566
16:47:05:237 INFO    : robotpy.installer   : -> Robot is at 10.15.66.2
16:47:05:238 INFO    : robotpy.installer   : Connecting to robot via SSH at 10.15.66.2
16:47:06:416 INFO    : paramiko.transport  : Connected (version 2.0, client OpenSSH_7.4)
16:47:06:609 INFO    : paramiko.transport  : Auth banner: b'NI Linux Real-Time (run mode)\n\nLog in with your NI-Auth credentials.\n\n'
16:47:06:610 INFO    : paramiko.transport  : Authentication (password) successful!
IMAGEVERSION = "FRC_roboRIO_2019_v12"
-> ERROR: installer requires RoboRIO image 2020_v10! Use --ignore-image-version to force install
16:47:06:910 ERROR   : robotpy.installer   : Command (IV=$(grep IMAGEVERSION /etc/natinst/share/scs_imagemetadata.ini); echo $IV; [ "$IV" == 'IMAGEVERSION = "FRC_roboRIO_2020_v10"' ] || (echo '-> ERROR: installer
requires RoboRIO image 2020_v10! Use --ignore-image-version to force install' && /bin/false)) && echo 'set -e
PACKAGES=()
DO_INSTALL=0
if ! opkg list-installed | grep -F "python38 - 3.8.1-r0"; then
    PACKAGES+=("http://localhost:35581/opkg_cache/python38_3.8.1-r0_cortexa9-vfpv3.ipk")
    DO_INSTALL=1
else
    echo "python38 already installed"
fi
if ! opkg list-installed | grep -F "python38-robotpy-wpiutil - 2020.3.2.0"; then
    PACKAGES+=("http://localhost:35581/opkg_cache/python38-robotpy-wpiutil_2020.3.2.0_cortexa9-vfpv3.ipk")
    DO_INSTALL=1
else
    echo "python38-robotpy-wpiutil already installed"
fi
if ! opkg list-installed | grep -F "python38-robotpy-hal - 2020.3.2.0"; then
    PACKAGES+=("http://localhost:35581/opkg_cache/python38-robotpy-hal_2020.3.2.0_cortexa9-vfpv3.ipk")
    DO_INSTALL=1
else
    echo "python38-robotpy-hal already installed"
fi
if ! opkg list-installed | grep -F "python38-pyntcore - 2020.3.2.0"; then
    PACKAGES+=("http://localhost:35581/opkg_cache/python38-pyntcore_2020.3.2.0_cortexa9-vfpv3.ipk")
    DO_INSTALL=1
else
    echo "python38-pyntcore already installed"
fi
if ! opkg list-installed | grep -F "python38-wpilib - 2020.3.2.3"; then
    PACKAGES+=("http://localhost:35581/opkg_cache/python38-wpilib_2020.3.2.3_cortexa9-vfpv3.ipk")
    DO_INSTALL=1
else
    echo "python38-wpilib already installed"
fi
if [ "${DO_INSTALL}" == "0" ]; then
    echo "No packages to install."
else
    opkg install  ${PACKAGES[@]}
fi' > install_opkg.sh && bash install_opkg.sh && rm install_opkg.sh && ([ -x /usr/local/bin/pip3 ] || exit 87) && /usr/local/bin/pip3 install --no-index --find-links=http://localhost:35581/pip_cache/ --pre --upgra
de --no-deps pynetworktables robotpy-wpilib-utilities returned non-zero error status 1
I realize it says I have to update to image 2020 for the roboRIO but I cannot locate where the 2020 image is. The imaging tool only updates up to 2019.
Please update the FRC Game Tools. See https://docs.wpilib.org/
I loaded up game tools and it was stuck on “No operations to be Performed”
You definitely need the 2020 image to compete in a 2020 competition.
Might want to reboot if the game tools aren’t installing and try again? Or uninstall the existing tools, then reinstall.
We got it all working, including having the 2020 image.
Awesome!
