Hello,
I’ve been trying to use the CANJaguar class with PID control, but due to a lack of examples and documentation it has been a lot of guess and check work. I have successfully created a CANJaguar object and correctly configured it to the point where I could get encoder feed back. However I have run into a bit of trouble trying to use PID Control with the robot.
Here is some sample test code I created for a CANJaguar based driveTrain: http://code.google.com/p/iraiders-frc-2713/source/browse/trunk/2012/test/CANTest/src/com/iraiders/subsystems/CANDriveTrain.java
My problem is that even after setting a setpoint value using setX(x), the driveTrain wheel fail to move. Testing shows that the method getX() returns a value of zero. What’s wrong? If anyone knows anything about the topic any information would be very helpful.
