PROBLEMS WITH AMP's!!!!!!!!!!!!!!!!!!
We found our problem with the drive train the 40 amps we got all cut out at any little movement if any other teams are having problems with amps blowing post and lest see what is up with the amps if its just ours or everyones im going to go tell FIRST! THANK GOD!!!
If you are using the bosch motors/transmission, then try shifting to the low speed/high torque gear. If not, grease your drivetrain (this fixed our problem with the 30’s).
Tton,
You have to be more specific, are you tripping the 40 amp circuit breakers? Does it occur all the time or just when you turn, do you have multi motor per side design? What is your gear ratio, etc.?
