Problems with cRIO
We’re having trouble connecting to our cRIO.
When trying an error like this appears:
Unable to complete operatuib because of unexpected error: error -2145024809 occured at nisyscfg.lvliv:Initialize
(Helper).vi
Possible reason(s):
LabVIEW: (Hex 0x80070057) One or more arguments are invalid.
NI System Configuration: (Hex 0x80070057) Invalid Parameter.
Complete call chain:
nisyscfg.lvlib:Initialize (Helper).vi
2012_nisyscfg_Initilize.vi
ConfigUtiltiy.lvlib
DiscoverDevice.vi:
ConfigUtiltiy.lvlib:
ReImageTarget.vi
ConfigUtility.lvlib:Dialog.vi
And another error some other times:
Unable to complete operation because of unexpected error:
Error 1 occured at TCP Read in NI_InternetTK_Common_VIs.lvlib: TCP Read xTP Reply.vi:14->
NI_InternetTK_FTP_VIs.lvlib:FTP Get Command Reply.vi:13->
NI_InternetTK_FTP_VIs.lvlib:FTP Open Session.vi->
ConfigUtility.lvlib:2012_FTPOpen.vi->
ConfigUtlity.lvlib:FRC 2012_FTP Get File.vi->
ConfigUtility.lvlib:OpenRemoteConfiguration.vi->
ConfigUtility.lvlib:ReImageTarget.vi->
Possible reason(s):
LabVIEW: An input paramter is invalid. For example if the input is a path, the path might contain a character not
allowed by the OS such as ? or @.
We’ve no idea where this is coming from.
We’re using the older, 2009 cRIO, not the cRIO-II.
I’ve seen the second error with an older cRIO, too.
I was able to get it to work eventually, but I haven’t had time to experiment with variations yet.
Here are some of the things I did:
  • Disabled all NIC’s but the one Ethernet port I was using for the cRIO
  • Did a Safe Mode reformatting (Safe Mode dip switch. reset the cRIO, run Imaging tool, turn Safe Mode switch back off, reset cRIO)
    *]Followed by a regular Imaging
We’ve seen this error also.
If you run ‘ipconfig’ from the ‘cmd’ window and see multiple ip-addr’s listed for your
ethernet port, the FIRST cRIO imaging tool fails.
You can delete the extra ip-addrs with ‘netsh’.
