Can’t deploy code to crio from windriver. crio is imaged, i’m getting a license error
In your Windriver installation disk there is a file that is your license. You have to copy and paste that into your program file—Windriver folder. Your not licensed and that is why your getting that error. You also want to check if your team number is set under Preferences in Windriver. After you click preferences go to FIRST Downloader and put in your team number and browse for the built .out file which should be in your Workspace folder. Just follow directions in this pdf: http://firstforge.wpi.edu/sf/docman/do/downloadDocument/projects.wpilib/docman.root.c_and_java_documentation/doc1197
This pdf has everything that you need. Just make sure you installed Windriver correctly. Then follow the downloading to robot instructions as well.
