Hi there again,
Sorry for posting so much stuff but I have been spending a long time coding this stuff and this keeps coming up now if anyone is able to help that would be awesome
Error at edu.wpi.first.wpilibj.MotorSafety.check(MotorSafety.java:101): DifferentialDrive... Output not updated often enough.
Also when I ran a simulator on the robot this started to happen
ng at edu.wpi.first.wpilibj.IterativeRobotBase.printLoopOverrunMessage(IterativeRobotBase.java:309): Loop time of 0.02s overrun
This is the code for what we got any help would be awesome.
/* Copyright (c) 2017-2018 FIRST. All Rights Reserved. */
/* Open Source Software - may be modified and shared by FRC teams. The code */
/* must be accompanied by the FIRST BSD license file in the root directory of */
/* the project. */
package frc.robot;
import edu.wpi.first.wpilibj.smartdashboard.SendableChooser;
import edu.wpi.first.wpilibj.Talon;
import edu.wpi.first.wpilibj.CameraServer;
import edu.wpi.first.wpilibj.Timer;
import edu.wpi.first.wpilibj.drive.DifferentialDrive;
import edu.wpi.first.wpilibj.XboxController;
* The VM is configured to automatically run this class, and to call the
* functions corresponding to each mode, as described in the TimedRobot
* documentation. If you change the name of this class or the package after
* creating this project, you must also update the build.gradle file in the
* project.
private static final String kDefaultAuto = "Default";
private static final String kCustomAuto = "My Auto";
private String m_autoSelected;
private final SendableChooser<String> m_chooser = new SendableChooser<>();
// Talon Controls
private Talon shoot = new Talon (1);
private Talon intake = new Talon (3);
private Talon Drive = new Talon (4);
private Talon Polocord = new Talon (2);
// Joystick Controls
private final Joystick bigJ = new Joystick(1);
private final XboxController xBox = new XboxController(0);
// Timer
public Timer time = new Timer();
// Constraints for the Joystick
private final double deadZone = 0.05;
// Diffrential Drive
private final DifferentialDrive move = new DifferentialDrive(new Talon(6),new Talon(7));
// Safety offline
* This function is run when the robot is first started up and should be
* used for any initialization code.
@Override
public void robotInit() {
// Chooser Code
m_chooser.setDefaultOption("Default Auto", kDefaultAuto);
m_chooser.addOption("Blue 1", kCustomAuto);
m_chooser.addOption("Blue 2", kCustomAuto);
m_chooser.addOption("Blue 3", kCustomAuto);
m_chooser.addOption("Red 1", kCustomAuto);
m_chooser.addOption("Red 2",kCustomAuto);
m_chooser.addOption("Red 3", kCustomAuto);
SmartDashboard.putData("Auto choices", m_chooser);
// Camera Server
CameraServer.getInstance().startAutomaticCapture();
// Data for motos
SmartDashboard.putNumber("DrivePower",0.82);
SmartDashboard.putNumber("ShootPower",0.5);
SmartDashboard.putNumber("IntakePower",.5);
SmartDashboard.putNumber("PolyCord",0.6);
* This function is called every robot packet, no matter the mode. Use
* this for items like diagnostics that you want ran during disabled,
* autonomous, teleoperated and test.
* <p>This runs after the mode specific periodic functions, but before
* LiveWindow and SmartDashboard integrated updating.
@Override
public void robotPeriodic() {
* This autonomous (along with the chooser code above) shows how to select
* between different autonomous modes using the dashboard. The sendable
* chooser code works with the Java SmartDashboard. If you prefer the
* LabVIEW Dashboard, remove all of the chooser code and uncomment the
* getString line to get the auto name from the text box below the Gyro
* <p>You can add additional auto modes by adding additional comparisons to
* the switch structure below with additional strings. If using the
* SendableChooser make sure to add them to the chooser code above as well.
@Override
m_autoSelected = m_chooser.getSelected();
// m_autoSelected = SmartDashboard.getString("Auto Selector", kDefaultAuto);
System.out.println("Auto selected: " + m_autoSelected);
* This function is called periodically during autonomous.
@Override
* This function is called periodically during operator control.
@Override
// ALL THE POWER
final double drivePower = SmartDashboard.getNumber("DrivePower",0.85);
final double intakePower = SmartDashboard.getNumber("IntakePower",0.9);
final double shootPower = SmartDashboard.getNumber("ShootPower",0.9);
final double polocordPower = SmartDashboard.getNumber("PolocordPower",0.6);
// The Safety Captian should not look at this section
intake.setSafetyEnabled(false);
shoot.setSafetyEnabled(false);
Polocord.setSafetyEnabled(false);
Drive.setSafetyEnabled(false);
if(xBox.getAButton() == true){
Polocord.set(polocordPower);
}else{
Polocord.set(0);
if(xBox.getBButton() == true){
shoot.set(shootPower);
}else{
shoot.set(0);
if(xBox.getXButton() == true){
intake.set(intakePower);
}else{
if(Math.abs(bigJ.getY()) > deadZone || Math.abs(bigJ.getX()) > deadZone){
move.arcadeDrive(bigJ.getY()*drivePower, bigJ.getX()*drivePower);
// this is old scripts but are no longer current due to us trying a diffrent method
// Polycord Script
if(xBox.getRawButton(0) == true) {
}else{
Polocord.set(0);
// Shooting
if (xBox.getRawButton(5) == true){
}else{
shoot.set(0);
// Intake
if (xBox.getRawButton(4) == true || xBox.getRawButton == true){
}else{
intake.set(0);
move.arcadeDrive(bigJ.getY()*drivePower,bigJ.getX()*drivePower);
* This function is called periodically during test mode.
@Override
public void testPeriodic() {
