Problems with Netbeans imports
Hello, I’m not familiar with Netbeans, as I prefer IntelliJ and I don’t like Netbeans at all… Anyhow, I have a little problem with it. When I create a new template (extending IterativeRobot) and try to import the following classes:
  • import java.io.File;
  • import java.net.URL;
  • import java.net.URLClassLoader;
Netbeans cannot find them. I tried everything I could think of: reinstall the plugins, create normal Java project and write the same code (it actually worked fine in a normal Java project). Please help if you can.
Thanks.
Why are you using Netbeans? It’s not a supported IDE for 2015.
You’d be better off using Eclipse and following the installation steps for WPILib on the screensteps webpage
Right, I just thought of that myself, bye Netbeans…
