baig
Trying To Run QDriverStation. But I am getting an error:
ERROR: Cannot connect to robot
FRC: The robot is slow to respond. Check firewall settings.
My wifi is finding the robot’s network. Is anyone else having this issue?
And if so, how did you get the driver station to connect?
thanks
spat
Well, it seems that the QDS cannot find your roboRIO. Try to ping your robot with the following command:
ping roboRIO-4761-FRC.local
Then, locate the IP address that the command outputs and place it in the “custom address” textbox in the Settings Window:
That should solve your issue, if not, you can contact me at: alex_spataru@outlook.com
