I am having a problem setting up the connection. i cant find the kernal file i need. somebody help me please
The Kernel Image file should be found in the WPILib folder in your WindRiver installation directory (“C:\WindRiver\WPILib” by default). Make sure you use the right file for your cRIO version; “cRIOFRC_vxWorks” for an 8-slot cRIO or “cRIOFRCII_vxWorks” for the newer 4-slot version.
If the WPILib directory is not there, make sure you have installed the C++ update for 2013 found here: http://firstforge.wpi.edu/sf/frs/do/viewRelease/projects.wpilib/frs.2013_frc_update_for_c.mid_season_c_software_update .
There is an excellent set of instructions for the whole process found over on the control system documentation site: http://wpilib.screenstepslive.com/s/3120/m/7913/l/79733-configuring-wind-river-workbench .
thank you very much! i will be sure to remember your team name when the competitions roll around!
