Hello, Chief Delphi. I am posting on behalf of Team 3175 because we are having major problems. For the past 3 days, we have been having trouble with our Victors (888, if it helps), because they are not responding when we put any value into them. We have tried putting different sidecars in, using a different PWM cables, using different Victors, using Ethernet cables instead of wireless, and using a different cable from the crio to the sidecar. All the victors are powering fine, but whenever we try to use them, only 2 out of 6 Victors respond, but which 2 are random every single time. This is not a motor problem, as we have tested, but we need an answer immediately, as B&T is tonight.
Thank You in advance,
Team 3175.
