That message is telling you that your RobotDrive wasn’t updated for over 100ms. So the safety mechanism set it to zero for you. This is a good thing if you happen to be debugging your code or you slow it down accidentally.
Do you know which loop it is referring to? It may just be in your teleop. Do you see any reason why teleop would take a long time to finish? A common issue is to place a delay to sequence an action directly into teleop when a button is pressed or a target is seen. This causes that iteration of teleop to take a long time and the message is printed.
If you see many of these messages, it may be worth instrumenting teleop and other loops to see how often they are running. To do this, the project window has a folder called support code. The Elapsed Times VI can be placed into the teleop or other loops. Then run the code on the robot in debug mode and open the Elapsed Times panel. It will show you the delta between each call. Between this and the CPU usage on charts, you can identify if loops are running faster than you need, slower than you want, etc.
Greg McKaskle
