Our program will not download. What might be the cause of this?
We have it all connected and driver station can connect to it, it just doesn’t download.
What programming language are you using? This makes a big difference in the download procedure.
Java
Make sure that either your firewall is disabled or that there is an explicit exception for Netbeans.
What is the error that you are seeing?
Which computer are you using to download code? What IP address is it set to? Are you using Netbeans for your Java development?
