Hi,
I was wondering how you configure current limiting on the new TalonFXs?
I’ve been trying the typical
motor.enableCurrentLimit(true);
motor.configContinuousCurrentLimit(35);
motor.configPeakCurrentDuration(250);
motor.configPeakCurrentLimit(50);
motor.configOpenloopRamp(.4);
and it doesn’t work
I think I need to use motor.configGetSupplyCurrentLimit(); but I don’t know what to pass through it.
Thanks in advance.
Jacob_C
January 11, 2020, 12:09am
The Talon FX Class uses the new Current Limiting API. It’s a single call that takes a “CurrentLimitConfiguration” object with all of your current limiting parameters.
https://phoenix-documentation.readthedocs.io/en/latest/ch13_MC.html#new-api-in-2020
The calls mentioned in the documentation are here:
configSupplyCurrentLimit
configStatorCurrentLimit
The Supply Current Limit is the current limit you’re used to - the current going into the motor controller that you typically want to limit to prevent breaker trips.
The Stator Current Limit is new for Talon FX/Falcon to be able to limit the current draw of the motor itself.
Thank you that helped. Marked
January 10, 2021, 12:11am
