programming error
Each time im going to run the program so i can burp the compressor the error " Expected β€˜:’ or end-of-line" appears. Is there something wrong with the program. :confused: .Also i need to find some tutorials for 3dsmax 4.2.
ps is there a particular way in which you have to connect the OI and the computer so u can program the OI
well, you can’t program the OI, cause it’s not ment to be. for the error you’re getting, it sounds like you renamed a variable, or misspelt one, and then you tried to set it equal to a number. i’ve gotten that a lot, and it’s always been because of a stupid mistake i made, or becuase i was editing the code, and deleted something.
