Programming Help Needed
We are using arcade drive, and we want to know how to program our CAN Talon Motor to work with Daisy-Chain configuration, can anyone help us?
I can. Due to the proximity of bag and tag, I suggest you private message or email me and I’ll send you my phone number.
Due to the way CAN works, it’s really the same as if you were to wire the “in parallel” (internals of the SRX make it so that “daisy-chained” is really in parallel also).
There is this previous thread that may be helpful
https://www.chiefdelphi.com/forums/showthread.php?t=133687
(they are saying to use a resistor at the end of the chain - the pdp has that resistor built in, so if you don’t move the jumper on it you can terminate there)
One tip that I can give you is to wire them all up, then pull the breakers to the Talons. go into the web configuration and put one breaker in at a time and refresh (that way you know which one is showing up) and assign CAN addresses as fits your needs.
The other tread covers the “Daisy-Chain configuration” very well, but you also asked “how to program our CAN Talon”.
See attachments
Did you look at section 3.4 in our Talon SRX Software Reference Manual?
