Hi, I’m wondering how to code a robot to run in autonomous just to move forward to the baseline. The code that the Robot Builder looks like a base code, I’m wondering what I have to add to it for it to work.
// RobotBuilder Version: 2.0
// This file was generated by RobotBuilder. It contains sections of
// code that are automatically generated and assigned by robotbuilder.
// These sections will be updated in the future when you export to
// Java from RobotBuilder. Do not put any code or make any change in
// the blocks indicating autogenerated code or it will be lost on an
// update. Deleting the comments indicating the section will prevent
// it from being updated in the future.
package org.usfirst.frc6397.Robot6397v5.commands;
import edu.wpi.first.wpilibj.command.Command;
import org.usfirst.frc6397.Robot6397v5.Robot;
public class AutonomousCommand extends Command {
// BEGIN AUTOGENERATED CODE, SOURCE=ROBOTBUILDER ID=VARIABLE_DECLARATIONS
// END AUTOGENERATED CODE, SOURCE=ROBOTBUILDER ID=VARIABLE_DECLARATIONS
// BEGIN AUTOGENERATED CODE, SOURCE=ROBOTBUILDER ID=CONSTRUCTOR
public AutonomousCommand() {
// END AUTOGENERATED CODE, SOURCE=ROBOTBUILDER ID=CONSTRUCTOR
// BEGIN AUTOGENERATED CODE, SOURCE=ROBOTBUILDER ID=VARIABLE_SETTING
// END AUTOGENERATED CODE, SOURCE=ROBOTBUILDER ID=VARIABLE_SETTING
// BEGIN AUTOGENERATED CODE, SOURCE=ROBOTBUILDER ID=REQUIRES
requires(Robot.driveTrain);
// END AUTOGENERATED CODE, SOURCE=ROBOTBUILDER ID=REQUIRES
// Called just before this Command runs the first time
protected void initialize() {
// Called repeatedly when this Command is scheduled to run
protected void execute() {
// Make this return true when this Command no longer needs to run execute()
protected boolean isFinished() {
return false;
// Called once after isFinished returns true
protected void end() {
// Called when another command which requires one or more of the same
// subsystems is scheduled to run
protected void interrupted() {
Just call the command you used for driving in teleop for a certain amount of time.
Our team used mecanums for the entire drive base, so a simple command to use for mecanums is mecanumDrive_Polar(1 (magnitude: speed in a direction), 0 (angle: direction in degrees), 0 (rotation: speed of rotation independent of the other two))
The following example assumes that your Robot.driveTrain subsystem has a method called arcadeDrive(throttle, steer) in it that can be used to set power to the drive motors and that you want to want to drive at a certain power for 5 seconds.
A TODO comment has been included in each section indicating that you will need to make adjustments based on your robot and the methods you have available in your subsystem.
// TODO: Change to your subsystem's method that moves the robot
Robot.driveTrain.arcadeDrive(0.5, 0.0);
// TODO: You will need to determine how long you want it to keep driving
double driveTimeSecs = 5.0;
return (timeSinceInitialized() >= driveTimeSecs);
// TODO: You will want to call the method in your subsystem that stops the drive
Robot.driveTrain.arcadeDrive(0, 0);
end();
Hope that helps, or at least gives you a starting point to work from.
Sorry to ask again, but could you clarify if my DriveTrain DOES indeed have the method called arcadeDrive? I see it here, but I don’t know if it’s what I’m supposed to have. Thanks.
package org.usfirst.frc6397.Robot6397v4.subsystems;
import org.usfirst.frc6397.Robot6397v4.RobotMap;
import org.usfirst.frc6397.Robot6397v4.commands.*;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.Spark;
import edu.wpi.first.wpilibj.SpeedController;
import edu.wpi.first.wpilibj.command.Subsystem;
public class DriveTrain extends Subsystem {
// BEGIN AUTOGENERATED CODE, SOURCE=ROBOTBUILDER ID=CONSTANTS
// END AUTOGENERATED CODE, SOURCE=ROBOTBUILDER ID=CONSTANTS
// BEGIN AUTOGENERATED CODE, SOURCE=ROBOTBUILDER ID=DECLARATIONS
private final SpeedController speedController1 = RobotMap.driveTrainSpeedController1;
private final SpeedController speedController2 = RobotMap.driveTrainSpeedController2;
private final SpeedController speedController3 = RobotMap.driveTrainSpeedController3;
private final SpeedController speedController4 = RobotMap.driveTrainSpeedController4;
private final RobotDrive robotDrive4 = RobotMap.driveTrainRobotDrive4;
// END AUTOGENERATED CODE, SOURCE=ROBOTBUILDER ID=DECLARATIONS
// Put methods for controlling this subsystem
// here. Call these from Commands.
public void initDefaultCommand() {
// BEGIN AUTOGENERATED CODE, SOURCE=ROBOTBUILDER ID=DEFAULT_COMMAND
setDefaultCommand(new DriveWithJoystick());
// END AUTOGENERATED CODE, SOURCE=ROBOTBUILDER ID=DEFAULT_COMMAND
// Set the default command for a subsystem here.
// setDefaultCommand(new MySpecialCommand());
public void takeJoystickInputs(Joystick DriverJoy) {
robotDrive4.arcadeDrive(DriverJoy);
public void stop() {
robotDrive4.drive(0, 0);
Your drivetrain subsystem does not itself contain a method called arcadeDrive, however, robotDrive4 does a have method called arcadeDrive which is able to output to all of your drivetrain motor controllers.
You are currently using arcade drive with a joystick as input which is perfectly fine for teleop, however, it clearly won’t be the signature of arcade drive you will want to use, rather: arcadeDrive(double moveValue, double rotateValue) with
“@param moveValue The value to use for fowards/backwards @param rotateValue The value to use for the rotate right/left”
Either reference the robotDrive4 directly in your command or create a method in your drivetrain subsystem that inputs both moveValue and rotateValue for the arcade drive to a call of arcade drive on the robot drive.
