keeps saying i failed the flash
Is there an error code or something? Is your Limelight setup from a previous year?
No just this year
Doesnt say any error code
Aaron,
Can you re-download Etcher from the downloads page? The 2+ actually requires the newest version which was linked on our site very recently.
i have the regular 2 not the 2+
regardless, i’m able to download etcher multiple times (lag made it 3 extra copies)
Sending a PM
99% of the time flashing problems are caused by a faulty USB cable or a USB cable that doesn’t have the data lines (charging only cable).
just got it flashed, now moving onto the networking
I think this is ok. you only need it if you intend to connect to the limelight with an mDNS address e.g. http://limelight.local:5801
Otherwise you can use limelights ip finder tool and hard code those ip addresses (for now)
stuck on this step, i’m not able to connect to limelight.local:5801
Don’t connect to the mdns address. Instead, connect to the 10.TE.AM.xx:5801 where xx is found using the limelight finder tool.
on LL finder i see
Broadcasting (10.16.65.32)
Perfect put “:5801” after that address and you should be good to go
so enter this in the web address bar
limelight.local.10.16.65.32:5801
the robot’s currently wired as
radio <-> rio via ethernet
radio <-> laptop via ethernet
LL <-> PDP
Nope, just use 10.16.65.32:5801 . Limelight.local is an mdns domain, totally separate from an IP address, which doesn’t use mdns at all. Usually IP is more reliable.
it’s refusing to connect
could this wiring have anything to do with it?
I decided to just POE directly from Laptop and was able to access the limelight.local.5801
Next qustion: How is the GRIP Engine applied to the LL?
I have it downloaded and it goes by the name “GRIP.exe”
