programming
I recently downloaded the V7 master code with easy C V2. My robot will not go out of autonomous mode. If I put a jumper in interupter 6, it goes to operator control, however it does not exit out of autonomous mode under normal circumstances. I had the controller on when I tested this, and it still does not work. Please help. Thanks.
I figured it out. Turns out I had the wrong version of the master code V7. It works now though.
