We are just trying to figure out the pinout to our code and exactly how that works with the PSOC Board. . . After looking at all of my known resources I could not find any examples.
We are looking at hooking up a Potentometer, couple 2 position switches, and couple LEDs.
We hooked up the PSOC board to the classmate and downloaded the FRC_v2.hex file using the PSOC programmer and it shows the green light on the Dashboard of driver mode.
Looking at the pinout of the Cypress PSOC board on http://www.usfirst.org/roboticsprograms/frc/content.aspx?id=10934 I miss where you set if its a digital output or digital input?? Is this set in Windriver? (we are using C++). (I also see the documentation at http://www.cypress.com/?rID=38235)
Can someone post an example on how to hookup and program an analog, digital output, digital input to PSOC Board.
I THINK. . .
Analog 1 is P0_0 and value can be retrieved from driverstation->GetAnalogIn(1)
Digital Input 1 is P4_4 and value can be retrieved from driverstation->GetDigitalIn(1)
Digital Out = ?!?!?! do you have to designate that digital channel 2 (P4_5) is out somewhere??
I just don’t want to start hooking switches, LEDs, and pots up without knowing the hardware ahead of time
