Psuedorandom numbers
Well I have been studying psuedorandom sequences for Microchip microcontrollers based on seeds and so far the fastest I have found is thusly from mondo technology:
chop    movf    val1,w     ;get the 1st
        addwf   val2,w     ;add the 2nd
        movwf   val2       ;store the 2nd
        addwf   val3,w     ;add the 3rd & store
        movwf   val3       ;back in 3rd
        addwf   val1       ;add back to 1st
        swapf   val1       ;swap nibbles
        movf    val1,w     ;return one byte
        ret
It looks to be 10 instruction cycles long. However, I would like to see some other methods as I have found that this particular algorithm tends to repeat numbers after a short while with only a 24-bit seed. Does anyone else know of some psuedorandom sequences (C, ASM, or Psuedocode please)?
Quite a bit longer than 10 instruction cycles but here is what our prof made us use for a lab earlier this year:
static unsigned long int SEED_X = 521288629L;
// this is a 32-bit constant
static unsigned long int SEED_Y = 362436069L;
unsigned int random()
static unsigned int a = 18000, b = 30903;
SEED_X = a*(SEED_X&65535) + (SEED_X>>16);
// requires 16X16 multiply, 32bit add
SEED_Y = b*(SEED_Y&65535) + (SEED_Y>>16);
return (SEED_X + SEED_Y)/2;
// requires 32bit add, 32bit shift
We had to implement this in ASM for our Lab before we started C so I have an ASM implementation, if you want to see it PM me.
use a linear congruential generator - probably the best in terms of ease of use to simplicity ratio. It’s on wikipedia
-Salik
