how do i press the play button in expert mode?
like is there a hotkey or anything?
Yes, the hot key is /
I have attached a file you may want to check out. I did NOT create this, I merely had it. Hope it helps.
maxShortcuts.pdf (59.1 KB)
Learn the hot keys. Study them. The very BEST way to learn a new program is to make flash cards and quiz yourself on the hot keys.
I would disagree, quizzing yourself is unnecessary*. Print a sheet of them and reference it as needed. In all honesty you probably wont ever need most shortcuts. The ones you use often will become familiar very quickly.
*Of course, I need to add a disclaimer, some people learn very well from just reading, others from doing. I learn from doing so I can’t stand quizzes and studying. You need Learn how your brain is wired to learn.
