Pyntcore 2020.1.2.0 now available!
What is pyntcore?
pyntcore are python wrappers around the C++ ntcore library. Because all the heavy lifting and threading is done in C++, in theory this should result in significantly less overhead for your python programs that would normally use pynetworktables.
How to install? Requires python 3.6+:
python3 -m pip install pyntcore
Where’s the documentation?
… there isn’t any yet. Soon? The API should be fairly close to pynetworktables – in fact, if you install pyntcore, it’ll also install pynetworktables for you. When pynetworktables detects pyntcore, it will use that internally.
$ python -c 'import networktables; print(networktables.nt_backend)'
pyntcore
I’d love for people to try this out and let me know where the API differs from pynetworktables. Several of the pynetworktables examples work with pyntcore.
