To preface: sorry if this is the wrong subforum, not sure if this would fit better in programming (not really programming related either though).
This year we are using a CMUCam5 Pixy for vision… and it works well, but white balance and auto exposure seem to reset or change after turning the robot on and off.
In PixyMon, disabling auto exposure, auto white balance, and auto white balance on startup cause the Pixy to stop getting a video feed. Any ideas? Is there a way I can set the exposure/white balance manually in a config file so we don’t have to worry about calibrating before every match?
Thanks in advance
If this information helps: the Pixy is wired to an analog port on the Rio, and using the 5v power from that. We need camera brightness (in PixyMon signature pane) to be very low to take advantage of the reflective tape/LED ring.
