Question about IP Camera rules
My team is planning to use a Hikvision IP cam instead of the Axis IP cam for this year’s game, are there any limitation for what IP camera we could use and what other things should we watch out for (Ex. stream protocols, port, ip address, camera authentication, bandwidth limitation)?
Thanks in advance.
Key constraints:
  • 4 Mbps bandwidth limit
  • $500 cost limit
  • Use ports 80 or 1181-1189 (full list is in the manual)
The standard dashboards only support MJPG stream format, but you’re free to do something custom if you want in terms of the stream format.
Thanks Peter! That solved my questions!
