Question regarding buddy climb and rule 6.5.2
When considering a buddy climb and the rule in 6.5.2 does having a robot on your buddy climbing system count as 2 robots climbing? Or does only one count because only one is technically in contact with the cage?
If so, if the robot on the buddy climbing system was able to contact another cage but still be on the buddy system, would that then count as contact with the cage and award both as a climb?
There’s no rule on 2 robots touching the same cage afaik. I assume it will probably be updated soon clarifying exactly what you can do. As for touching 2 different cages it should count as 2 different climbs.
