How does the reputation ranking work?
I highly doubt I will be the first to post something since there is 4 other people on the page. But Iām going to take a shot at it anyway.
Here is a link to a post that explains how people can give it out and what not : http://www.chiefdelphi.com/forums/showpost.php?p=278682&postcount=4
If you like (or dislike) someoneās post, you click on the little scale at the top right of the post. This brings up a little window with three options and a blank. Choose the rep option you want to give (positive, neutral, or negative), then type your reason into the blank. Submit it. Iām not sure of limits on how much you can give or when you can start giving it, but they are there. I also donāt know how the little green (or red) boxes are configured.
anyone can click on the little scales icon on the upper right of any post, and give + neutral or - rep for a post.
Once you give someone rep points, you have to give rep points to a certain number of other people before you can give it to that person again.
People with lots of + rep points have more influence (impact) when they give you rep.
The idea is for the forum to be self-monitoring to some degree. If someone tells you its a good idea to short out your battery with 6 gauge wire when you are not useing it, and you look over and see they have 5 red squares (negative) then you take their advice with a grain of asprin.
Genrally speaking, negative rep should only be given to someone whoās post or behaviour is unacceptable, not simply because you dont like what they say, or dont agree with it.
Thank you guy and gals
Correct me if Iām wrong, but Iām pretty sure that the amount of rep you can give is based on your post count, not on your current rep. And, if you have less than 50 posts, you canāt give good or bad rep.
If you read the post that I linked to, it tells you how much rep points you can give out based on your post count; how long youāve been on CD; and what not.
[edit]
So no one actually has to click the link, iāll just qoute the post thatās qouting another post
[quote=āBillfredā]
Well, Brandon had this to say a few threads backā¦
So thatās half of the battleā¦[/quote]
