Hello Everyone. I am writing some arm code for our test bot this year. The arm has two Neo motors, one on each side, with a 300 to one gear ratio. It also has a CANcoder as its absolute encoder.
I am trying to get the arm moving with the spark maxes PID controller, and had some questions about following.
Currently, I am getting the encoder and pid from one spark max, having the other spark max follow it. The set up the spark max encoder with the gear ratio and have it match the position of the absolute encoder. I then just use the spark max pid controller in position mode to try and reach the desired position.
I am wondering if the follower will still follow the leader since I am using the leaders PID controllor, and also if this is the correct way to do this arm code in the first place.
Thank you!!
Full Code:
package frc.robot.subsystems.arm;
import static frc.robot.subsystems.arm.ArmConstants.ARM_CONFIG;
import static frc.robot.subsystems.examples.flywheel.FlywheelConstants.GEAR_RATIO;
import java.util.function.Supplier;
import com.ctre.phoenix6.configs.CANcoderConfiguration;
import com.ctre.phoenix6.hardware.CANcoder;
import com.ctre.phoenix6.signals.AbsoluteSensorRangeValue;
import com.ctre.phoenix6.signals.SensorDirectionValue;
import com.revrobotics.CANSparkBase.ControlType;
import com.revrobotics.CANSparkBase.IdleMode;
import com.revrobotics.CANSparkLowLevel.MotorType;
import com.revrobotics.CANSparkMax;
import com.revrobotics.RelativeEncoder;
import com.revrobotics.SparkPIDController;
import com.revrobotics.SparkPIDController.ArbFFUnits;
import edu.wpi.first.math.util.Units;
public class ArmHardwareIO implements ArmIO {
private final CANSparkMax leader;
private final CANSparkMax follower;
private final RelativeEncoder encoder;
private final SparkPIDController pid;
private final CANcoder cancoder;
private final Supplier<Double> absolutePosition;
private final Supplier<Double> relativePosition;
public ArmHardwareIO() {
// --- Create Hardware ---
leader = new CANSparkMax(ARM_CONFIG.leaderID(), MotorType.kBrushless);
follower = new CANSparkMax(ARM_CONFIG.followerID(), MotorType.kBrushless);
cancoder = new CANcoder(ARM_CONFIG.encoderId());
// --- Set up CANCoder ---
CANcoderConfiguration armEncoderConfig = new CANcoderConfiguration();
armEncoderConfig.MagnetSensor.AbsoluteSensorRange =
AbsoluteSensorRangeValue.Signed_PlusMinusHalf;
armEncoderConfig.MagnetSensor.SensorDirection = SensorDirectionValue.Clockwise_Positive;
armEncoderConfig.MagnetSensor.MagnetOffset = ArmConstants.ARM_ENCODER_OFFSET.getRotations();
cancoder.getConfigurator().apply(armEncoderConfig, 1.0);
absolutePosition = cancoder.getAbsolutePosition().asSupplier();
relativePosition = cancoder.getPosition().asSupplier();
// --- Set up leader controller ---
encoder = leader.getEncoder();
pid = leader.getPIDController();
// --- Configure Spark Maxes ---
// Defaults
leader.restoreFactoryDefaults();
follower.restoreFactoryDefaults();
// Conversion Factor
encoder.setPositionConversionFactor(1 / GEAR_RATIO);
encoder.setVelocityConversionFactor(1 / GEAR_RATIO);
// Set follower to copy leader
leader.setInverted(ARM_CONFIG.leaderInverted());
follower.follow(leader, ARM_CONFIG.followerInverted());
// Enable brake
leader.setIdleMode(IdleMode.kBrake);
follower.setIdleMode(IdleMode.kBrake);
// Voltage
leader.enableVoltageCompensation(12.0);
leader.setSmartCurrentLimit(30);
// Save config
leader.burnFlash();
follower.burnFlash();
// --- Match encoder positions ---
encoder.setPosition(absolutePosition.get());
@Override
public void updateInputs(ArmIOInputs inputs) {
inputs.positionRads = Units.rotationsToRadians(encoder.getPosition());
inputs.velocityRadsPerSec = Units.rotationsPerMinuteToRadiansPerSecond(encoder.getVelocity());
inputs.absoluteEncoderPositionRads =
Units.rotationsToRadians(absolutePosition.get());
inputs.relativeEncoderPositionRads =
Units.rotationsToRadians(relativePosition.get());
SmartDashboard.putNumber("Position", Units.radiansToDegrees(inputs.positionRads));
SmartDashboard.putNumber("Velocity", Units.radiansToDegrees(inputs.velocityRadsPerSec));
"AbsPosition", Units.radiansToDegrees(inputs.absoluteEncoderPositionRads));
"RelPosition", Units.radiansToDegrees(inputs.relativeEncoderPositionRads));
inputs.appliedVolts =
new double[] {
leader.getAppliedOutput() * leader.getBusVoltage(),
follower.getAppliedOutput() * follower.getBusVoltage()
inputs.supplyCurrentAmps =
new double[] {leader.getOutputCurrent(), follower.getOutputCurrent()};
@Override
public void runSetpoint(double positionRad, double feedForward) {
pid.setReference(
Units.radiansToRotations(positionRad),
ControlType.kPosition,
0,
feedForward,
ArbFFUnits.kPercentOut);
@Override
public void runVolts(double volts) {
leader.setVoltage(volts);
@Override
public void stop() {
leader.stopMotor();
@Override
public void setBrakeMode(boolean enable) {
leader.setIdleMode(enable ? IdleMode.kBrake : IdleMode.kCoast);
follower.setIdleMode(enable ? IdleMode.kBrake : IdleMode.kCoast);
@Override
public void configurePID(double kP, double kI, double kD) {
pid.setP(kP, 0);
pid.setI(kI, 0);
pid.setD(kD, 0);
pid.setFF(0, 0);
