We are toying around with several drivetrain ideas in offseason, and had a couple questions about using VersaDrops with 4" mecanum wheels and VEX clamping gearboxes as shown on the octocanum tab of the VersaDrop product page.
The Toughbox Micros we used this year with 6" AM mecanums had a LOT of “slop.” The wheels could easily turn a good half inch without actually turning the motor. We dissected the gearbox and it was a combination of the hub on the mecanum wearing down and the first gear on the output shaft causing this. Would using VEX clamping gearboxes with VersaDrop result in this same “slop” after a fair amount of use? We need the gearing to be tight enough to work well with a Talon SRX and encoder for velocity closed-loop control.
That brings me to my next question… has anyone mounted an encoder to either the VersaDrop or the clamping gearbox? I was wondering if a CIMcoder would fit on the CIM output shaft as well as the gear and the clamping gearbox’s motor mount. The CIMcoder page says it takes 0.31" off the output shaft, if that helps…
Lastly, JVN’s spreadsheet tells me I could get an adjusted 13.4 ft/s with a 14:70 gear and 16:18 sprocket reduction with the 4" mecanums. This year’s robot felt slow to us, with an 8.54:1 ratio on the 6" AM mecanums. How accurate is the spreadsheet’s estimate? We’re aiming for 12+ ft/s, so this would be perfect if the estimate comes close.
Thanks in advance
