Hello to the rather specific part of the FIRST community I am targeting,
I was reading over OPR calculation and other such calculations in order to calculate offensive contributions and some ideas started to weasel its way into my head, therefore I must pursue them. I should pick up the R language relatively easily, as it seems to share many common elements with Python and Matlab. I was wondering are there some resources that you guys could point me towards to aid with my learning? I am slowly falling deeper end deeper into the statistical analysis rabbit hole and any help to ease the future confusion I may have is greatly appreciated.
One of my housemates went through an entire semester of Biometry working straight from the shell, it made my skin crawl. A proper GUI is a must and was installed mere seconds after I installed R.
[EDIT]
I have been using this website as an introduction. It is geared more towards novice programmers but seems to provide strong overviews of the various components of Rstudio.
The plan is to slowly work to that. I have a lot of learning to do. I have bookmarked that thread for later use, thanks for linking it in though.
I have some concerns about my package palette. I am sure I will find what I need in time through trial and error; but is there anything additional packages that may prove generally useful that are basic ‘need-to-haves’?
I’m not sure if you’ve seen the other thread that addresses R and OPR, but I wrote an R package for downloading and manipulating FRC data in R. You might find it useful to peruse the source code, which is on github. I also have links to the R resources that I used in the Getting Started Guide for the package. Links to everything are at http://irwinsnet.github.io
For others who may not have seen it yet, there is a short paper here that shows how to use sparse matrix technology in R to speed up OPR computation by a factor of 10 or more.
Fall into that rabbit hole! Learning R will have much bigger payoffs down the road. Many of the best statisticians I know use it and it can be a tremendous work skill to have.
I know plenty of languages and I am familiar with the syntax of more than I care to admit, but R is so syntactically different than most… It has some nice bits too, but dang it can be annoying…
