When strategizing with my team, the question came up whether or not we could have a piston, for example, that would extend in front of the bumper. I’ve crudely drawn a together a couple of diagrams to demonstrate what I mean.
and at some point during the match, to pick up a boulder, for example, the pistons would extend and form something like this: https://i.imgur.com/qxxBdCI.jpg
When checking the rules, I came across R4 which states
In the STARTING CONFIGURATION (the physical configuration in which a ROBOT starts a MATCH), no part of the ROBOT shall extend outside the vertical projection of the FRAME PERIMETER, with the exception of minor protrusions such as bolt heads, fastener ends, rivets, etc.
However, this only states that the robot can’t start with something extruding past the bumper. Would I be able to extend something below the bumper like that?
Keep reading. BACKWARDS in this case, to R3B. You’re just fine, provided that it’s retracted to start and <=15" past the Frame Perimeter when deployed.
Bumpers do not count as part of the frame perimeter. You can’t start the match with anything outside your perimeter. But otherwise yes, you may extend 15 inches outside your frame perimeter DURING the match.
The rules you want to review are those regarding the Frame Perimeter (mainly R2-R4) and those regarding bumpers (mainly R19-R28). It’s generally helpful to get in the habit of thinking of the rules in the language used in the manual, so you can be descriptive when asking about specific configurations.
Looking at your illustrations, it’s hard to tell where the retracted position is relative to the Frame Perimeter, but the general concept seems to be within the scope of the rules.
