Radio Channels
Does anyone know how to get 8 O/I’s and R/C’s working together with no interference?
I am already aware of the 6 channels you can access by changing the channel dip switches on the O/I… but i need to run 8 of them not 6… Is this possible?
I don’t know of a way to do 8 channels. I called them once to ask and was also aware of the 6 channels. (Tried to set this up for the Muncie Pre-Invitational this year.)
Actually if you are getting 6 channels to work together, you are VERY LUCKY. Really there are only 5 channels that will work.
From the manual:
“Note: Do not use Channel 31 and 40 at the same time with the 2007 or newer Radio Modems, interference between these Channels can cause intermittent radio communications.”
See PDF page #16
Does anyone know if the 06 radios have this same problem?
