I have try to config the new radio, but when i lunch the FRC Radio Configuration , i don’t show any network interfaces, but I can acces to radio in navigator. I have try many PC, many cable and all time the same problems, thanks for your help.
Hello,
I followed this guide directly from the Andy Mark webpage.
http://files.andymark.com/OM5P-AN_QuickAP_Setup.pdf
The process was extremely smooth. If you have trouble, let me know and I may be able to assist.
Here is another set of instructions for using the standard FRC Radio Configuration Utility for this year. Notice it is not installed with the LabVIEW update this year.
http://wpilib.screenstepslive.com/s/4485/m/13503/l/144986-programming-your-radio-for-home-use
What do you mean by navigator? Have you tried disabling your firewalls?
I can confire the radio at 192.168.1.1 but in FRC Radio Configuration, I see this : http://image.noelshack.com/minis/2016/02/1452873589-capture.png](http://www.noelshack.com/2016-02-1452873589-capture.png)
What Operating System do you use? Do you have the latest version of Java? Try disabling your computer’s firewall. You should be able to see the network interfaces without being connected to the radio.
Maybe you need to run as Admin?
Check your Network Connections and make sure your network connection is enabled.
Control Panel\Network and Internet\Network Connections
I uses win 7 x64 and I have disable the firewall and connection is enable, I have java but i’m not sure if is really active.
what worked for us:
-Run as Admin
-ethernet cable connected to the edge of the router, not the middle one
We do this, but we have always the problems.
My guess is that the configuration tool is not happy with a French-localized version of Windows.
Finally windows in french is the problems, but now, i have this new error message : http://image.noelshack.com/minis/2016/03/1453149857-rooter-bug2.png](http://www.noelshack.com/2016-03-1453149857-rooter-bug2.jpg)
