my team is trying to do a demonstration running multiple robots each with their own controls and ifi system but the radios are interfering with one another any idea how i could change the radio channel so they could run together?
Radio channel, for the IFI systems, is set by a block of 4 dip switches. I forget which setting is which channel, though. The block is on the left side of the display, and the channel may be viewed with the OI’s “Select” button.
To enable the alternate channels on an IFI operator interface from 2005-2008, you have to have the team number set to a value of 2048 or higher, so that the most significant bit is a one. (If you change the team number to meet this requirement, remember that you’ll have to tether the robot so that the RC can recognize the change.)
Here is what my cheat sheet says about the channel dipswitch settings:
1 2 3 4 Channel
X ON ON ON 04
X ON ON OFF 13
X ON OFF ON 22
X ON OFF OFF 31
X OFF ON ON 40
X OFF ON OFF 01
X OFF OFF ON 40
X OFF OFF OFF 40
This information is in the IFI control system documentation.
Also a note: Two of those channels interfere with each other (although i can’t for the life of me remember which two). At off season mini competitions, we FREQUENTLY ran into that when running 6 robots on the field at a time - 1 or two robots would become disabled seemingly “randomly”, causing much frustration.
