We have successfully loaded the firmware and the configuration to the radio, but the wifi will not turn on, and we cannot find it when we turn on our wifi to be found. Can someone help me troubleshoot, please? Thanks so much!
I would try to reimaging the radio using the steps in the WPILIBs manual.
Also make sure that your radio has adequate power from the PDP and is working (power light on)
Thanks so much! My guy says we have already done this.
Well in that case the radio could be dead. However, as the person who deals with electronics firmware for our team I would recommend attempting to reflash the radio as I rarely see radios die. If that doesn’t work though I would see if you could find a old radio and see if you could get that to work.
Thank you so much! We will get right on that.
