I have been trying to implement the Ramsete Command for trajectory following, but I have been running into problems of which I have no idea how to fix. So far, I have been able to create and run trajectories with the Ramsete Command to make the robot move straight or backwards x amount of meters, but any other type of trajectory has so far been a failure.
This is because very time we tell our bot (which consists of 6 motors controlled by spark MAXES using differential drive) to end at say position (1,1) with an end rotation of 0, the motors repeatedly oscillate while going on its diagonal path from (0,0). The motors even oscillate when I try to run trajectories which only manipulate the heading of the bot. I have referred to other posts noting of similar problems which point to PID and how the voltages are fed into the motors, but after ensuring the drive.feed() methods are in the right spots and after manually tampering with my 2 PID controller’s Kp and Kd values to try to dampen the effect, I have seen no improvement thus far.
I do believe this may be an over correction problem with the PID, but changing the constants didn’t do me any good. I have reviewed my code and ran additional motion profiling tests for the PID vals, but I still can’t figure out how to fix it.
My code is accessible here, and is based off of the Ramsete Comand example provided by wpilib. If someone has any Idea how to go about this, I’m all ears. Thanks!
