Range Sensor (best for Rev Control Hub)
We typically use the Modern Robotics Range Sensor (45-2008) with our Robots. But, we like to find something more accurate.
Any advise?
Rev sells a 2m range sensor that we used for basic positioning in Skystone. When detecting off the clear field walls, it was semi accurate up to about 120cm. We tested it with paper in front of the field walls as well which increased its accuracy considerably.
